Minimum RPM????
RE: Minimum RPM????
ORIGINAL: ibedanny
Clogs something in the engine is what he told me. If you ride under 6.
ORIGINAL: whtan20
Any technical explaination? I hardly go over even 5000 rpm when street riding..
if you dont know, dont post.
Riding at low rpms is normal and is best for economy and reduced engine wear. Nothing will get clogged...[sm=smiley24.gif]
3000-5000rpms is ideal cruising range under all circumstances
RE: Minimum RPM????
You'll get more carbon deposits down low and the fact that the pistons and crank dont spin that fast or as fast as they should it doesnt get the oil warm enough and carbonizes the motor more then it should. You should beat the crap out of it once in a while its healthy. I used to keep mine at 4k and now keep it at 6k and she loves it.
Btw the gas mileage thing is garbage. I get 140mi before hitting the reserve when i cruised at 4k and now i cruise at 6-7k and get the exact same **** using super.
