miles per tank or reserve? which ever comes first....
RE: miles per tank or reserve? which ever comes first....
Also, how much do you weigh? I weigh 150 lbs and I can get 150 before my reserve hits. If you ride with passengers you will get worse mileage. How high do you ride your rpms? All these factors play a part. Have you done anything to your bike to increase performance? ie. sprocket, 520 conversion?
Your reserve is calculated by a ratio of how you are riding your bike and what speed and such. It is not calculated by how much gas you have left in the tank.
That is why you are getting different numbers of gas mileages when you are comparing to other people. They should be ruffly the same though.
ORIGINAL: DThompson
I usually get around 120-130miles before my light comes on, I am 180lbs, and ride in the upper RPM range most of time.
ORIGINAL: DThompson
