Middle light in headlight Cluster
Old 07-05-2006, 12:12 AM
Dice's Avatar
Default Middle light in headlight Cluster
Just wondering if Honda ever had a 3rd globe in the F4i cluster or if anyone here has done their own mod.
Looking at the cluster from the outside, it seems like an allowance was made for it.
Old 07-05-2006, 12:47 AM
Default RE: Middle light in headlight Cluster
I think the European model had a position light there in the middle. I know what you are talking about, and have contemplating running a wire off the front parking lights and sticking an led in there myself.
Old 07-05-2006, 01:49 AM
Fox's Avatar
Fox
Fox is offline
Globe?
Old 07-05-2006, 02:53 AM
Dice's Avatar
ORIGINAL: mikem317
Globe?
bulb then for the Americans
You know here in Australia we call 'flashlights' torches?
Old 07-05-2006, 03:15 AM
Fox's Avatar
Fox
Fox is offline
Sorry... elevators are lifts and gasoline is petrol, yadda, yadda, yadda.
Dont' mind me. I'm the typical, uncultured American.
So basically make it look like a 600RR?
Old 07-05-2006, 03:34 AM
Dice's Avatar
Btw, Yadda yadda is the aboriginal term for a one legged kangaroo.
Well, if not a 600RR, then a euro spec F4i.
Old 07-05-2006, 03:40 AM
Fox's Avatar
Fox
Fox is offline
I guess you can try to fabricate it... I just ride with both lights on...
[IMG]local://upfiles/1268/A8A09376F4C54176B69FBBAC4FF39E60.jpg[/IMG]
Old 07-05-2006, 10:28 AM
I think hes talking about adding a light here, but correct me if I'm wrong. I think it would look cool if it was done right.
-Jesse-
[IMG]local://upfiles/3901/518CA39BF2B54691977A2D17000E5F5C.jpg[/IMG]
Old 07-05-2006, 11:01 AM
Dice's Avatar
Exactly right Jesse.
If you have a close look, it appears theres a spot for it but I couldn't feel any scoring or cap on the back so the hole for the bulb would have to be drilled, maybe.
If I can pick up a headlight cluster from a wreckers, I'd definitely try it.
Old 07-05-2006, 06:39 PM
you should be able to drill a hole in the back of the housing and put a small bulb there. check ebay oo, I have seen headlight housings go for a little of nothing.
-Jesse-
Quick Reply: Middle light in headlight Cluster
