LP short stalk bulb gets burnt!
Old Dec 2, 2005 | 04:47 AM
LoNeProBE's Avatar
Default LP short stalk bulb gets burnt!
Hi, I just installed Lockhart phillips short stalk ll dual filament marker light for front turn signals.
But the bulb 12V23 8W got burnt in a few days.
It was on as running light and flashing at correct rate ok.
Do I get smaller wattage bulb to prevent this?
Any experts out there, please advise!
Thanks
Old Dec 2, 2005 | 07:41 AM
abadfish's Avatar
Default RE: LP short stalk bulb gets burnt!
Is it wired correctly?
You probably have the running light on the 23W filament and the flasher on the 8W filament. It should be the other way around.
check this out:
http://forums.cbrworld.net/forums/120485/ShowPost.aspx
Old Dec 2, 2005 | 03:32 PM
LoNeProBE's Avatar
Thanks, I'll checked it out tonight!!!
Old Dec 2, 2005 | 03:40 PM
BeeJ's Avatar
Hey , i'm running sort of the same, the 12V23/5W. There almost the same thing, but mine burnt out really fast too, and the ones that worked actually burned the plastic casing. [:@]
I'm switching maufacturers cause it's a pain, Good luck
Old Dec 2, 2005 | 08:48 PM
LoNeProBE's Avatar
The stock bulb had the same 12V23V 8W.
So I figured I must have wiire it in opposite, running flash on 12V.
Still haven't fixed it yet!!
Old Dec 2, 2005 | 09:28 PM
chainstretcher's Avatar
Admin Emeritus & MVN
If it melted then it was wired wrong. The instructions should have warned about that. The running light is the low wattage element.
regener8ed
Mar 22, 2011 08:41 PM
__Z__
Feb 10, 2011 02:43 PM
cyrusyn
F2 Tech
Mar 16, 2010 06:13 PM
adams_CBR600f2
Mar 7, 2007 04:49 AM
06CBRF4i
Jul 11, 2006 11:31 PM
