Lower temp for fan to turn on
You must not live in a hot area. I love in phoenix, 115* is pretty normal during the summer. When its over 100* outside then f4i's will be over 200* even when cruising down the freeway. I've never had mine go over 228* even sitting at a stoplight forever so it doesn't worry me.
Am I basically just cutting the plug off the sensor and grounding one wire and wiring up the other wire to the factory wire?
Once I take the side off this weekend it will probably make sense just trying to get an idea.
Thanks for the help!!
Well I did this yesterday and found out I havent even had a fan for about a year now. There was a plug jammed in my fan that stopped it from working. After changing a fuse I found the sensor was bad so I put in the new one and everything works like a charm. Can't believe it took me that long to figure out my fan wasn't working, guess I just never pay attention to it. Oh and my fan turns on now around 200 which is nice!!
