Loose front neck
i didnt know if it was necessary or not but I removed the ignition from the triple with t40 hex tool to get the triple off, the 2 hex bolts were on pretty tight.. here are the two nuts.. part number 6 and 5... part number 7 is the lock washer with tabs..
http://fiche.ronayers.com/Index.cfm/.../STEERING_STEM
as for the palm vibrations from the engine, its not as much as it used to be but i heard if you get gel grips it helps a whole bunch..
Okay, so I did it today and like you said it was easy. My lock nut was not too loose, but it was not too tight either causing slight thumping/movement when you hit a bump or squeeze on the brakes.
I haven't rode since I tightened it, but I will see how it feels at a later time.
I didn't take a lot of pictures, but here is what the lock nut looks like if someone wants to see (actually, all you have to do is look under your top triple and you will see the lock nut, lock washer and adjusting nut).
There is a special too to tighten that nut and according to the manual, it only takes 18 foot/lbs of torque. I also had another problem, probably a result of going down, my steering stem nut was not tight at all. It took nothing to loosen it. I made sure that it was torqued to 76 ft/lbs when I was finished (as according to the manual).
Thanks for all of your help.
