Letting a motor idle...specifically the F4i motor
Idiling is quite easy on the motor. Rpms are low meaning there is very little bearing surface swept by the journals of the crank per minute. The engine isen't forcing as much oil through so theres less load on the oil pump and drive gear. The pistons are scraping the cylinder walls less often and there is almost NO cylinder pressure above normal cranking pressure which is the biggest cause of wear in the cylinders.
Long ago your friend would have been right, kinda. Idling would be hard on the spark plugs because carbs had horrible fueling issues. If it wasen't fueling correctly it could either be rich and foul plugs and lean and cause detonation.
On a real hot day in here Chicago my bike will get to 233 or 234 at a light which I believe to be normal. It should never get above 240 I would imagine if everything is working the way it should be.
BoredandStroked thanks for putting that into perspective! Sounds like you know your stuff
RDub-sounds about right....damn I miss Chi-town and the north side wrigley area...so many god d#$% gorgeous cultured women...I left a few back there when I came out west
Cant beat the AZ weather though and riding by mountains overlooking the whole valley on an open 5 or 6 lane highway never gets old
I'm not quite sure where you guys are getting this idea that when you turn your bike off its going to get hotter. Yes the cooling system turns off but so does the engine. There's no more friction, detonation, or work period. How does something get hotter when you arent adding any elements of heat? When you take a steak of the grill it doesnt magically get hotter than it was on the grill. It continues to cook because its still hot, not because its getting hotter.
This is the reason lots of cars have fans that run after you shut the car down and take the key out - to ward off heat sink by continuing to blow air over the engine to keep it cooler. In fact I believe there are a fair number cars now that have circulating pumps to continue to circulate Anti-Freeze.
EDIT - here is an article on this exact issue. The 3rd paragraph puts into perspective and notes that the Jaguar engineers designed a fan to deal with this EXACT issue. http://www.jaguarfuelinjectorservice...ing%20v12s.htm
Either way though - it doesn't matter. It isn't like it is going to overheat and crack the block or warp the heads. Just do what you feel like doing - let it idle, or shut if off, there probably isn't a right answer because the long-term effects from doing either are negligible.
I got to agree on seafordguy here. Have you ever turn off your bike then turned it back on a minute later only to see it is now at a higher temp than it was when you shut it off? If not try it.
I am not quite sure why you aren't understanding how that can happen. An engine block is operating at a hypothetical temperature while you are moving. It is operating at that temperature with the help of the cooling capabilities of the radiator, and the wind flowing over both the readiator, and the block itself. You slam on the brakes come to a stop, and shut the engine down. In the immediate time frame following that the engine has no way to continue to dissapate the heat at the same level and consequently the temperatures will rise until the heat is dissipated naturally.
Damn it would be sweet if our F4i's had the luxury option of having a circulating pump and fan running after a hot shut down
science experiment:
if you shut the bike down but leave the key on the fan will continue to run (if it was on)... and the temp gauge will still be on... then you could watch you temp gauge go up a few when you shut it down... then drop a lot shortly after
But as others have said, do what you want. The bike is going to run forever as long as you change the oil.
But isn't the voltage required to start the bike a greater drain on the battery than idling?
How many times have you heard guys idling their bike for a half hour while they went in to do something, only to hear it die out and find a dead battery? Fan + Lights + Engine is drawing on the battery.
