LED supplier website
Old Mar 7, 2009 | 09:22 AM
MC_spirited's Avatar
Default LED supplier website
I was a link on here a while ago for a site that has a good selection of LED's. Looking to do the intake signals and whatnot and I searched and went through some pages and didn't find anything. Anyone know what a good place is to buy LED's?
Old Mar 7, 2009 | 11:01 AM
StrikeAnywhere's Avatar
www.customdynamics.com
Old Mar 7, 2009 | 01:01 PM
Rozenheimer's Avatar
www.tripageled.com does the work for you, but they have a bunch of ideas you can work off of, if thats what you are looking for
Old Mar 7, 2009 | 01:11 PM
And www.oznuim.com has a great selection of prewired LEDs and LEDs without the resistors. Along with sets for motorcycles or anything you need LEDs on.
Old Mar 7, 2009 | 01:45 PM
Aken's Avatar
July 2008 ROTM
Originally Posted by rozenheimer
and www.oznuim.com has a great selection of prewired leds and leds without the resistors. Along with sets for motorcycles or anything you need leds on.
+ 849302
Old Mar 8, 2009 | 10:07 AM
Thanks for the replies guys. Im just wondering now what would be the best angle of for the light spread for the things i want to do.. I also want to get some bright white LEDS and make some halo's. I figure that if i go through the trouble of making two i might as well make more and sell some or maybe do i double ring for each high and low..
When you hook up LED's for accent lighting and whatnot what do you do for power? Just a fuse and tap into a circuit on the bike?
Old Mar 8, 2009 | 06:05 PM
Aken's Avatar
July 2008 ROTM
Power wire + fuse off the battery, or add-a-circuit off the fuse box.
Old Mar 8, 2009 | 08:49 PM
Liquidpjear's Avatar
If you are doing signals then the angle really wont matter, assuming the LEDs are going to be pointed forward. The only time angle is really important is for accent lighting when you need to light an area. Good luck with the rings, I have seen very few DIY setups that have any longevity and look good.
Do a fuse/distribution block if you are going to do lots of different lights. It makes things some much easier if you need to work on them or move/remove them. You can also do quick disconnects near the LEDs if they are going to be mounted on a panel you might want to remove.
e3737c
Feb 5, 2010 05:03 AM
Shadow
Sep 17, 2008 11:13 PM
95Cbr6
Sep 4, 2008 06:31 AM
Scrufdog
Jul 23, 2007 11:05 PM
Anubis
May 18, 2006 08:27 AM
