Layed it down...
Earlier today, I was moving my bike in my driveway, pulled in the dirt to make a wider turn and goosed it too much by accident, and not going more than 5mph the rear tire swung out and the right side mirror and blinker broke, as well as scratching the plastics up pretty good.
The exhaust is also scratched up which i am not worried about, however when I started it back up, the tach, speedo and everything wasn't on. Just the clock, high beam, and turn signal indicators worked. Could someone shed some light on what I need to fix to get those to work once again?
Thanks
Thanks
Thanks for the quick replys, I actually just rode it and seems to ride fine, I am just mad at myself, the only reason I moved it was to get the snow blower out (as I am moving right now). I guess this is my Friday the 13th luck for the day.
Looks like its scraped up on the front fairing, side fairing, mirror is snapped off, and blinker is dangling...so if anyone has these parts that match a 2005 red/silver F4I, I am now in the market.
dropping bike at slow speeds sucks because you think you could have done more to stay up. still, its way better than dropping at high speeds. sucks that this happened but did you have slidders? from the damage you received it sounds like you did not, no?
ORIGINAL: lifties
You should never ride your bike in dirt. Not that you need anybody telling you that now.
Sure, if you are riding a dirt bike.
ORIGINAL: chornbe
Every rider should start out riding in the dirt. Makes you a way better rider in the long run.
ORIGINAL: lifties
