launch master / clutch swith
Old Mar 16, 2009 | 04:44 PM
SmokeShank's Avatar
Default launch master / clutch swith
I picked up an MSD launch master off a fellow rider and went ahead and installed it last night. i got to the point of splicing into the clutch switch to enable the launch control. before i did so, i tested the wire agaisnt each side of the switch (at the lever). neither side would activate the launch box. i grounded the wire out against the frame and the box would work. i pulled out the wiring schematics and from what i can see is that the clutch switch is not a grounded signal.
does anyone have an idea how i can hook this up? the signal wire to the launch box, from the clutch line has to be grounded for the box to work. but like i said, from what i can tell, it seems all the clutch wires are actual signal wirings carring voltage, i don't see a ground on the switch wiring.
Thanks for any assistance.
-Smoke
Old Mar 16, 2009 | 04:45 PM
SmokeShank's Avatar
oh and i forgot
I figure if it is a postive clutch ciruit, i can tee the to a relay, and have the relay be the ground signal for the launch box. any thoughts on this?
Old Mar 16, 2009 | 05:12 PM
SmokeShank's Avatar
can someone check my work?
Old Mar 16, 2009 | 05:29 PM
Jaybird180's Avatar
Is this designed to retard ignition?
backdoc
How To ...
May 20, 2013 11:43 PM
badrhino
May 19, 2013 12:48 AM
cbr600joe
Jan 18, 2008 10:44 PM
Hotswap
Apr 8, 2006 04:29 PM
