Key won't turn, gas cap stuck.
I think I may have messed up my bike. My gas cap was having problems before, I would have a hard time getting it open. I had to wiggle back and forth and then get it open sometimes for 5+ minutes. So I opened it up, used WD-40 to lube everything as there were white dry spots everywhere. Now it was all lubed up and working I put it back together.
Now I tested it, the key won't turn, locking my gas cap. Any way to open it or fix it without damaging it? If I can't find any help on here I'm going to bring it into the mechanics tomorrow.
Thanks.
Thanks.
mine does it from time to time and thats what I do about once a year. but I've not had mine apart, so you may have a tumbler not falling into place like it should. Only thing I could think of it to remove the whole assembly and see if you can take it apart then to check it out.
