K&N air filter installation issues
Old Jun 12, 2010 | 04:36 PM
600x3's Avatar
Default K&N air filter installation issues
Ok, so I thought this would be easy, but so far it hasn't been. First, the little U at the bottom of the stock air filter is pushed to one side a little bit, vs the K&N has it right in the center. With it being right in the center it doesn't fit right.
2nd, am I supposed to put the K&N directly into the stock air filter spot, or am I supposed to be putting it inside of the plastic contraption that the stock air filter is in. It looks like I will destroy the screen and maybe something else if I go to put the K&N inside the plastic piece that fits into the cutout.
Not sure if any of this makes sense, but hopefully the pics will explain. It just doesn't look like it fits. I bought it brand new and it's the correct part number per the K&N website. HA-6001.
Attached Thumbnails K&N air filter installation issues-285.jpg   K&N air filter installation issues-287.jpg   K&N air filter installation issues-289.jpg
Old Jun 12, 2010 | 04:41 PM
Krux's Avatar
Just put it in and screw the box back in. I think your over looking it
Old Jun 12, 2010 | 05:19 PM
600x3's Avatar
So it's not a "good" fit? The stock filter holder has the filter up at an angle, the K&N doesn't seat well since it's laying flat. Is that normal?
Old Jun 12, 2010 | 05:29 PM
Krux's Avatar
should just fit right in flat. Are you sure you got the right one? Any numbers or anything on it?
Old Jun 12, 2010 | 07:52 PM
Da11en47's Avatar
When I got mine, I thought it wasn't going to fit properly as well. But I think I had to flip it or reverse it, which didn't seem right at the time, but fit perfectly. Try some things, hopefully you got the right one though.
Old Jun 12, 2010 | 10:07 PM
600x3's Avatar
Default I am a retard!!!
Geez, I'm going to have to give up my man card for a month for this one. I had it upside down. I just thought it would fit like the stock one looked, but apparently not. Anyway, I'm back up and running now. Thanks for the advice. Gained 4 mpg when I put my D&D pipe on last week. Hopefully I can pickup another 1-2 with the K&N. I wouldn't think it would, but then again, I never dreamed a pipe could make that kind of difference either. 42.5 before the pipe, 46.25 with the D&D, maybe 47-48 with the K&N?
Thanks guys!!!
Old Jun 12, 2010 | 10:10 PM
Krux's Avatar
That's pretty good gain. Oh ya stop having stuff flipped around, we don't need your bike to be the next thing flipped around
Old Jun 12, 2010 | 11:25 PM
Zero1080's Avatar
Glad to see it's solved. That little screw is there just to hold the airbox cover on anyway. But you don't need to give up your man card just yet. Just your common sense one :P
Old Jun 13, 2010 | 09:29 AM
skameigh's Avatar
Lol I did the same thing installing my K&N Filter... I had a wtf moment but then after about 15 minutes wondering why the hell it didnt fit I then had my facepalm moment... Flipped it over and viola!!
Old Jun 13, 2010 | 12:55 PM
vangill's Avatar
July 2010 ROTM
my k&n has writing on it that says "this side faces up" or something like that. does nobody else's have that on there? its molded in from the manufacturer on mine.
im not bein mean, but just curious
