K&N air filter installation
I'm going to install my K&N this weekend along with my PCIII. The PCIII shouldn't be a problem...but the air filter I'm not quite sure about. I haven't taken off the fairings yet and looked at things, but does anyone have a link to step by step instructions on how to do this for a 2005 CBR f4i?
RE: K&N air filter installation
First, take off both side fairings. Then take off both ram air duct covers, there's two 5mm hex bolts on each one. Next, take off the seat and loosen the two boths that hold the back part of the tank on - only loosen them 1 or 2 full turns, don't take them out. Then completely remove the front two bolts that hold the tank on, right next to the triple tree. Find a prop rod that won't scratch your paint and prop up the front of the tank (12"-15") and make sure it's secure so the tank won't come slamming down. Then, unplug the wiring harness on top of the air box, then remove the bolts that hold the top of the air box on - can't remember how many, but there's a bunch. Then take off the top of the air box and switch out the filter. Then put it all back together (don't forget to plug the wire harness back as it was) and it should all be done. Here's a pic:
This is a photo of everything off except the top of the air box, right under the tank.
[IMG]local://upfiles/4409/176D1E8E62114ED6B78FBAAF1FC00606.jpg[/IMG]
ORIGINAL: SquireSCA
Actually, you only have to remove the duct covers, you can leave the fairing panels on.
ANy reason you are going K&N?
Most things I have read said that the best performance is actually with the stock filter, unless you do a full exhaust. Also, the K&N's let in a lot more dirt into the motor.
And while it is washable, that costs money too for oil and cleaning solution and it takes alot more time to clean, oil and dry it. I would just rather toss in a new stock filter every 5k miles and be done in 20 minutes and get back to riding.
