It just shuts down.....
What's crackin' y'all?
Well, I think I'm dwindling down the issues list of this damn bike....but anyway....
Right now the problem is....the bike keeps shutting down. I was traveling down the highway the other day at about 90mph when all of a sudden the bike kept surging like it was running out of gas, but it wasn't gas. It was the whole bike (power/electrical included) shutting on and off very rapidly. Almost like a loose connection. It lasted for about 15 seconds and then stopped. I tried to draw all the power I could so I turned on the highbeams, blinker, and started honking the horn.....yes....all while going 90, lol. It would intermittently loose power. All connections are TIGHT. Also, sometimes when I am at a stop light or going real slow, I pull in the clutch and it dies. Not a choke like low on fuel.......more like "pull the plug" straight up dies, instantly. But it doesn't happen all time. Maybe once or twice a day....sometimes more since the issue is getting worse. I'm thinking stator or dying battery. Any thoughts would be fricken AWESOME! Thanks in advance guys!
~Ryan
~Ryan
My NOOb guess here:
Can It be the kickstand switch? As you know if the stand is down it kills the engine if the clutch is released while in gear.. so if it's deffective it could cause it to kill it while riding at 90mph. Although it shouldn't cause it to loose all of your electical power. Just a thought.
Possibly the clutch neutral switch is shorting out? It prevents the bike, while in gear,
starting if the clutch isn't pulled in. Check the switch and the neutral sensor (not
sure where the sensor is, though).
The r/r could be the cause as well, so here's a couple of links on that...
https://cbrforum.com/forum/f2-tech-9...-solved-27739/
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
Ern
Ern
My NOOb guess here:
Ern
Ern
a faulty tip sensor would cause the problem... but they usually dont go. To bypass i believe you connect the outside two wires together. Colors i have in a manual are red/white and green and the middle is white. I believe that is correct. Someone please correct me if i am wrong. You normally splice them together but i imagine you just wanna test this so make a bridge out of wire to put the two together. If that doesnt work id look towards the charging system
^^ That's a sick lookin' bike bro!
FOUND IT!!!!!!!!!!!! After a 44 oz cup last night filled with Sailor Jerry and Pepsi I went to work on the bike. It was the big gray harness in the front of he bike. It's the one covered with a big rubber boot. Well.... It clips in together to hold tight, right? (just like all other harness's) but on one side the clip broke. So the harness was becoming disconnected. This harness feeds your headlights, fuel pump, F.I. ****, and your ECU. Bingo.....problem solved!!!
Thank you guys for trying to help! I truly appreciate it!
~Ry
~Ry
