Just bought an 04 F4i 1,850 miles still has the stock tires
Change them, tires are a critical safety component of your bike. Besides older tires becoming harder as they age, the improvements in tire technology over nine years is significant. The life you save may be your own....
What do I do if there is rust? How do I get it out?
Change them man, it's not worth the risk honestly. You can find really good prices on tires on the web too. I picked up a set of continental contimotions for around $170 shipped to my door, should be as cheap if not cheaper for your bike since the rear tire isn't as wide.
Dump out whatever fuel is left in the tank, DO NOT run the engine until you get that rust taken care of.
Either you find a used tank that is not rusty inside, or take the tank off to get it sand/bead blasted and then coated with KREEM, 2 layers better than 1.
