JDM Spec F4i, 180KMPH Restriction
Old Sep 11, 2015 | 11:13 PM
sodahyogesh's Avatar
Default JDM Spec F4i, 180KMPH Restriction
Dear All members , i have a F4i here in India and unfortunately the bike is restricted to 180KMPH being JDM spec.
Can anyone help me with a quick and cheap fix to the restriction removal?
Old Sep 12, 2015 | 10:51 AM
coalminer frank's Avatar
I would find an on-line OEM supplier and compare part numbers. It might be as simple as replacing the ECU and thats it.
Old Sep 14, 2015 | 09:12 AM
Here are the pics from from the actual japanese spec F4i the intake manifold which carries a restrictive plate, we will be removing this plate too.
Attached Thumbnails JDM Spec F4i, 180KMPH Restriction-jap-cbr-600-f4i.jpg   JDM Spec F4i, 180KMPH Restriction-f4i.png   JDM Spec F4i, 180KMPH Restriction-img_2841.jpg   JDM Spec F4i, 180KMPH Restriction-img_2843.jpg   JDM Spec F4i, 180KMPH Restriction-img_2847.jpg
Old Sep 20, 2015 | 01:59 AM
Speedometer is designed to show only 180KMPH and even the self check is only upto 180. Does any one has the circuit diagram of the speedo mother board? or someone can send me pics of the US or EU Speedo motherboard to match with my JDM F4i?
Old Dec 27, 2015 | 06:52 PM
Zealot's Avatar
If you're sure that's a restrictive plate, you could start by replacing/removing that. Secondly, an ECU flash or simply buying another ECU/Ignition could be your ticket!
fuad
Mar 23, 2013 09:26 PM
Ryan Finkle
Aug 31, 2009 04:00 AM
maximdb1
Oct 5, 2005 07:22 PM
