Instrument Pannel Dead!!!!
Old Oct 6, 2007 | 11:06 AM
06F4IMike's Avatar
Default Instrument Pannel Dead!!!!
I rode my bike to work this morning and when i got down the roda from my house i noticed That my spedometer and tach and pretty much everything was out except for the clock! When i got on i know it was working because i was waiting for the temperature and it was working fine. I found that the fuse was blown so i replaced it but it keeps blowing whenever i turn the ignition on. Is this just a short? I havnt had time to dissasemble anything. Thanks
Old Oct 6, 2007 | 12:04 PM
oodie's Avatar
February 2009 ROTM
Default RE: Instrument Pannel Dead!!!!
Try to check the wires to see if they are touching anywhere. Have you changed anything recently? To you havea integrator on turnsignals? I know that i was messing with mine on day and it keep blowing the fuse.
Old Oct 6, 2007 | 12:28 PM
06F4IMike's Avatar
I have new signals all around which has been a while and a few days ago i put Blue Leds all the way around hooked directly to the battery and on there own fuse
Old Oct 6, 2007 | 10:28 PM
flypunk's Avatar
I had that happen to mine when I was doing some work on it. It turned out to be a blown fuse.
Old Oct 7, 2007 | 11:36 AM
06F4IMike's Avatar
Default RE: Instrument Pannel Dead!!!! and fixed
Yea the fuse was blown but it kept blowing the new ones. I found the short though. i i cut my tag light off and the tape came off the wires and the two were touching. Thanks guys!
Old Oct 7, 2007 | 02:29 PM
02cbrf4i4u's Avatar
Thats why you always saulder or buttclip when working with live wires like that!
Old Oct 7, 2007 | 10:57 PM
invalidalias's Avatar
dude I had the same thing happen to mine when I purchased it used. I had to take of the whole front fairing then take apart the whole instrument cluster. There are computer looking connections that everything plugs into in the back. Took about 1 hour to unbolt everything. Take your time taking it apart and putting it back together. Was a lose connection. Plugged it back in. Saved a couple 100 in labor
Old Oct 8, 2007 | 03:47 PM
06F4IMike's Avatar
yeahLesson for the day........It never pays off to be lazy! Do it right the first time to eliminate problems down the road! litteraly haha
Old Oct 9, 2007 | 01:15 AM
got_rice64's Avatar
i believe i had the same problem b4, after i low sided in the canyons. but i took it to a shop, and i they told me it was a short somewhere and fixed it for me.
BlueBerryPie
Feb 16, 2013 03:33 PM
emlynt2000
Nov 19, 2006 02:42 PM
NotSoMellowYellow
May 10, 2006 01:10 PM
