idling stalling issues?
Old Apr 26, 2012 | 07:25 PM
racecityjason's Avatar
Registered Users
Exclamation idling stalling issues?
here we go again! i have an 01 f4i i replaced the fuel pump when i bought it 600 miles ago, and the bike ran great with the exception of start up when hot it idles to low and stalls. but only when hot, i can hold the throttle slightly and after a few seconds the bike idles up and back down to the 1300 rpm. other then that its runs flawlessly. the newest quirk is the bike will suddenly and randomly act like it starving for fuel and try to die while riding always happens while rolling throttle on or shifting up through the gears, as soon as the clutch is pulled it will die. as soon as i stop and turn off the key immediately turning it back on and fire it up and ride away. and it may happen again within minutes or days. it has a brand new fuel pump, new FPR, new spark plugs, the bike has a jardine slip on with mid pipe, but other then that as far as i know its stock, any help or where to start looking for the problem would be great! thanks in advance guys!
Old Apr 26, 2012 | 11:07 PM
Registered Users
Default more 411
new info just came in from the garage and now i have nothing the headlight wont come on and the fuel pump wont prime, and the start button will not turn the engine over. im thinking bank angle sensor which would cut fuel while riding if it was acting stupid. i limped it into my garage when i got home and after 3 hours i got nothing, i jumped the fuel pump relay and it operates as it should, i also tried to bypass the bank angle sensor and still had no luck. any ideas?
Old Apr 28, 2012 | 12:02 PM
Registered Users
Fixed! Broken wire in the harness plug for the start button and cutoff switch
Old Apr 28, 2012 | 01:09 PM
An01InAZ's Avatar
that was going to be my answer. the switch box on the throttle side. 1 wire can screw things up lol
Old Apr 28, 2012 | 05:56 PM
cbrryno's Avatar
I had that happen and it was one of the wiring harness on the front of the bike. Glad you got it fixed bro.
hillbilly86
Jul 6, 2013 04:47 AM
clintthec
Feb 6, 2011 08:54 PM
zoomman113
Aug 2, 2010 10:21 AM
zoomman113
Jul 12, 2010 09:38 AM
crazycanasian
Dec 17, 2009 04:54 PM
