I need some help with some stock DIMENSIONS
Okay so with my project movin along here i need to know a couple measurements off the stock f4i and i am hoping you guys can help me out here...
whats the measurement front the bottom of the top triple mount to the bottom of the forks (i need this because with the r1 forks being a different size i would like to set them at the same ride height as stock for now)
and second im makin my own subframe so i was curious if someone could measure how long the top and bottom rails were on one side (like where they bolt to the frame to the end of it)... so i can get the general ida of the seat positioning angle...
thx guys...
Z
for example as far as the subframe
From A to B
And From C to D
thx guys...
Z
From A to B
And From C to D
All measurements are closest approximations...ie., not laser-exact.
Forks = 28-6/8 to 28-7/8 from bottom of fork to top of triple
'01-03 subframe...
A to B = 31.5
C to D = 31
Keep in mind that the split-seat subframe tubes aren't straight tubes from A to B or C to D like on the banana subframe...but distance is what I measured above.
Hope this helps.
'01-03 subframe...
A to B = 31.5
C to D = 31
Hope this helps.
