How to install a new foot brake lever?
Need some help here guys, still piecing the bike back together and need to replace the foot brake. Where do I start for install? Anyone have a good writeup or install vid? My stock lever basically snapped when it dug into the ground.
its not that bad.. use allen headed sockets to remove the 2 bolts that hold the rearset to the frame.. remove the heel guards with 2 smaller allen headed bolts..
You need a good snap ring plier to get the snap ring off that holds on the lever inside.. IIRC it was an external ring.. don't lose it! Remove that.. then the 2 springs that hold the lever on the rearset.. that's it.. slide the lever off the rearset.. install is reverse take pics along the way.. it will help in reassembly.. Adam |
If you have the service manual it will have some pictures to help you and step by step instructions.
