How to install a new foot brake lever?
on
1 Post
its not that bad.. use allen headed sockets to remove the 2 bolts that hold the rearset to the frame.. remove the heel guards with 2 smaller allen headed bolts..
You need a good snap ring plier to get the snap ring off that holds on the lever inside.. IIRC it was an external ring.. don't lose it! Remove that.. then the 2 springs that hold the lever on the rearset.. that's it.. slide the lever off the rearset.. install is reverse
take pics along the way.. it will help in reassembly..
Adam
Adam
