HOW to install cct on f4i??
i read a write up/sticky on an f2 i dont think there the same, and ive seen vauge steps on an f4is omethnig about a crank and somethnig im not sure on the f2 writeup it doesnt say anythnig about a crank, exactly how DO you install one of these step by step someone hep thanks alot need to make a stickie on all models and or tell what directions are the same for similar models/engines so the question is
how do you install a cam chain tensioner in an f4i perferably a 2002 model
thanks
ima shoot for the steps let me know if its good
1 get to cct and take it off, will it just slide out after i undo the 2 bolts?, if not what do i have to do
get manuel one and install allthe way screwd out, bolt new one on anythnig i have to lign up or anythnig when doing this if so what?, tighten with finger til snug start it put it in neutral and tighten til rattle stops.. let me know what else i have to do thanks
thanksima shoot for the steps let me know if its good
Remove fairings, tank, and airbox to get to it. Unbolt it, good luck with the bottom bolt, its a pita. I ended up cutting the "L" off my allen wrench and using a socket with the long part of the allen. Scrape off any gasket residue, then replace with new gasket. While the old one is out use it as a guide for setting the length of the new one. (Not screwd out all the way, same distance from mounting surface to the end that makes contact with the cam chain) As a precaution, dont let the bike roll any while its out. Not sure how you're supposed to start the bike with the tank removed, I didn't. I haven't had any rattles yet.
Mid-ish range revs (mine was around 3-6000ish rpm's) sound like something is seriously rattling, for a better use of words.
The worse the rattling gets, the closer the cam chain tensioner is to giving out, and if the timing skips...say goodbye to your motor.
In addition to the B.A.R.F. link, here's another if you want to cross reference
http://www.bossturbo.com/cbr/howto_cct.shtml
