hotbodies flushmounts
Old 08-05-2007, 11:12 AM
xtremef4i's Avatar
Default RE: hotbodies flushmounts
Hmmm.... sounds wierd. Do you have LEDs for the rear also? If you do, there might not be enough load and less resistence for the signals to blink. If that is the case you may need some load equalizers or resistors to connect in line with the flushies
Old 08-05-2007, 03:27 PM
JDubF4i520's Avatar
no i have stock blinkers in the rear
Old 08-05-2007, 11:03 PM
Make absolutely sure you have your polarities correct.
Switch around the wires and it should work. Otherwise, get a conductivity tester and start poking around!
Old 08-06-2007, 03:16 AM
RojerLockless's Avatar
ORIGINAL: Maranag
yup he beat me too it.. and make sure the wires are not touching each other otherwise it'll do what you are describing
Old 08-06-2007, 12:55 PM
JDubF4i520's Avatar
man all the wires are good and nothing is touching. i think i just F*(%^&D up my flushmounts cause neither one of them works now
Old 08-06-2007, 01:47 PM
refer to my diagram on this thread:
https://cbrforum.com/m_354131/mpage_.../tm.htm#354943
Old 08-06-2007, 05:21 PM
JDubF4i520's Avatar
lol thanks for the help bro but obviously your not reading my post...i said all the wires are perfect fuse is good so that diagram does me no good
Old 08-06-2007, 11:51 PM
ikhoudvanu199's Avatar
my guess?
the right flushie is busted...something in there is not completing the circuit when its hooked up...try testing for a circuit through it using the conductivity tester
Turbulenz
01-30-2010 08:41 PM
hero
08-16-2008 10:20 PM
WhiteGuyBlackBlade
10-10-2007 08:50 PM
beachaccord
06-02-2006 03:20 AM
Quick Reply: hotbodies flushmounts
