hotbodies flushmounts
Old Aug 2, 2007 | 08:15 PM
JDubF4i520's Avatar
Default hotbodies flushmounts
ok so i was just trying to install my flushmounts and my dumbass did something wrong.... i installed the left blinker and tested it to make sure it was working...worked perfect....so then i go onto the left flushie and install it but forgot to test it out...so i put my fairing back and and go to test them and now neither blinker works. checked the fuse and thats good any idea what i did wrong and how to fix it?
Old Aug 2, 2007 | 08:26 PM
JDubF4i520's Avatar
Default RE: hotbodies flushmounts
notices a mistake. i said left flush twice. so i installed the right flushie 2nd
Old Aug 2, 2007 | 08:50 PM
firemanron's Avatar
I'd say check your wiring on the right blinker. some how they work in conjunction with each other. well that is what I found out. Were your fuses ok though?
Old Aug 2, 2007 | 10:28 PM
devlzluv's Avatar
curious do u have a integrated tail, if so did u put the slow down thingy on it?
Old Aug 2, 2007 | 10:32 PM
xtremef4i's Avatar
meke sure you didnt get the red and black mixed up and that your wiring is correct with the back of the box. I just installed mine last night ant they are awsome. they are pretty bright
Old Aug 3, 2007 | 12:32 AM
JDubF4i520's Avatar
dude even with them unplugged my damn back blinkers dont work either....did i short something out? easy to fix?
Old Aug 3, 2007 | 07:29 AM
xtremef4i's Avatar
mabey a fuse but double check all your grounds and bulbs
Old Aug 3, 2007 | 01:33 PM
JDubF4i520's Avatar
fuse is fine i even put a new one in and still nothing. does someone have a diagram of the set up.
Old Aug 3, 2007 | 01:46 PM
JDubF4i520's Avatar
on the flushmounts the 2 red and black wires have copper wire beneath and the a silver type or wire at the top. on one of my wires the silver part fell off so now its only copper wire there would that be a problem or should it still work? ive checked everything and all the wires are correct fuse is good and still no blinkers at all front or back
Old Aug 3, 2007 | 01:59 PM
JDubF4i520's Avatar
ok i got the back blinkers working now....i cant have the flushmounts connected otherwise no blinkers work at all. as soon as i disconnect the flushies my back blinkers start working again
