Hooks/Grommets on the Fairings, HELP ASAP!
Old Jul 15, 2006 | 01:03 AM
markobenin's Avatar
Default Hooks/Grommets on the Fairings, HELP ASAP!
Hey I got all the bolts off of the fearing and the "clips" on the bottom, however I can't seem to get these "hooks" out of the "grommets" at the top as specified in the manual. I would yank on it but I don't know if that's correct and I don't wanna break anything. Help ASAP would be appreciated, I need to change my oil/filter tonight!!
Old Jul 15, 2006 | 01:21 AM
thirdgenlxi's Avatar
Ironmang
Default RE: Hooks/Grommets on the Fairings, HELP ASAP!
Why are you taking the fairings off to change the oil?
But to answer your question, are you referring to the top of the fairing where it goes into the grey air duct cover? If so, those are just pushed in and if you just kinda wedge your fingers in there behind the fairing and gently give it a good tug it'll just pop right out
Old Jul 15, 2006 | 01:39 AM
markobenin's Avatar
Ok I'll try that, I know I don't HAVE to remove the fairings, but I heard some oil drips in between them if you don't remove them...so I don't want a dirty bike :P
Old Jul 15, 2006 | 05:03 AM
markobenin's Avatar
Ok I just replaced the oil and the filter without a problem, as for the fairing, i just had to tug on it a lil more, I was afraid to break something in the beginning, but it's not very difficult. My question is...HOW THE HELL DO YOU CHANGE THE OIL WITHOUT REMOVING THE FAIRINGS?? That's ridiculous, not only am I amazed at how you can remove the oil filter from that angle, but how you manage not to get oil all over the place.
Old Jul 15, 2006 | 12:52 PM
Ironmang
It's super easy on the F4i... RR you do need to take the fairings off cuz the oil filter is sideways and it's the only way to get it off. But the F4i the filter is a straight shot right between the 2 header pipes, just turn the front wheel and use a filter socket with an extention and a ratchet, and it comes right out. Just be careful taking it out and it won't spill all over everything.... as soon as it's unthreaded tip the filter up so it doesn't drain out. Very little oil gets on the inside of the fairings, and if any does I just wipe it up right away and clean it off with cleaner. Then spray the header pipes with brake cleaner to get any oil off those (and it'll still smoke a little the first ride after), and you're good to go!
Old Jul 15, 2006 | 02:44 PM
buckd44's Avatar
yes.. I spent 1 hour before I gave in and bought the $6 socket.
Old Jul 15, 2006 | 02:46 PM
buckd44's Avatar
the part you are talking about looks like a philips screw head and is black??
BrandNew2002
F4i - Wanted
May 18, 2011 03:10 PM
