Hidle high mount won't lemme go 2 up.
Hey all,
As many probably know I recently aquired an 03 F4 i w/ a Hindle titanium high mount exhaust system. Unfortunately, the brakect utilized for the mounting of the pipe doesn't accomadate passanger pegs (the one on the right side is not prestent, and the bracket for the exhaust replaces the peg bracket for the right side). I was wondering what I would have to do to make my bike 2 person friendly. I don't plan on taking anyone for a long 2-up ride as I'm sure the heat from the exhaust probably poses a problem.
Could I use a different bracket? or is there a way to modify my current setup slightly? I was thinking that it might be possible to just buy the stock rear brackets and place the peg bracket directly on top of the current bracket.
Help appreciated.
Matt
Help appreciated.
Matt
RE: Hidle high mount won't lemme go 2 up.
i guess the ghetto low-tech solution is to shim the pass pegs out to where they clear the canister, and bolt them into the subframe. just be sure you don't give fat chicks or girls who can leg press 900 lbs rides.
the easy solution is to get a "low mount" or stock exh which mounts to the peg, i'm sure someone will trade for your pipe. it looks pretty nice.
Yeah, the thing of it is I really don't know if I want to sacrifice the highmout for the sake of taking people out, I have thought about switching pipes to a stock one. I rarely give anyone a ride, but there is always that off chance you know. [>:]
Matt
Matt
REALLY trying not to flame.... This post including 4 AWESOME pics was about 4-5 below your new topic.
https://cbrforum.com/m_474991/tm.htm
any hardware store will have something, just take some measurements so you know how long you need. did the bike come with the passenger pegs? Like FiendCBR said... 2 longer bolts, two "shims" to extend the peg out over the pipe. Be sure to get a high grade bolt though, the amount of torque that can be put on those bolts could definately bend them.
