HID problems help!
Old Jun 11, 2014 | 11:12 PM
Jeffy_2010's Avatar
Default HID problems help!
Okay so here is the problem, I have had HID's installed for about 3 years not had a single problem, just the other night I noticed my high beam wasn't lighting, I un-plugged it and plugged it back up and it light so I thought problem solved. Tonight the hi beam did the same thing again, but this time I noticed, when I flip my switch, the ballast will make a loud buzz/zapping sound when trying to light the bulb.. Sometimes it will fire up and sometimes it won't. Any idea on what's going on? Bad bulb or ballast?
Old Jun 17, 2014 | 01:58 AM
Ser Jon's Avatar
If the block hoots, and the lamp is lit every other time - a problem in a lamp.
Old Jun 18, 2014 | 07:39 AM
Ser Jon's Avatar
Change places of connection of lamps to ballasts and you learn in what the reason.
Old Jul 9, 2014 | 10:23 PM
jeremymik84's Avatar
sounds like a bad ballast, swap the ballast from your low beam to high beam and see if it works
m21oliver
Oct 1, 2018 10:52 AM
clintthec
Jul 27, 2011 06:04 PM
honda23
Jun 28, 2011 12:24 PM
cr cbr
Nov 28, 2006 04:36 PM
