HELPPPPPPP >>>>>>NO rear brakes !!!!!!!
this may seem stupid but make sure your bleeding it properly. first check your resivor make sure you have fluid in it then when your done top off the resivor. what you want to do is open the bleeder valve make sure you can get it open then close it all the way. pump the breaks, then push the pedel down all the way open the valve. close the valve before you let the pedel come up, then pump the breaks again and push the pedel all the way down and open the valve then close it and let the pedel up and repeat till there is only solid break fluid coming out. if you dont close the the bleeder before you let off the pedel you could draw air into your brake caliper. it might take more then one resivor to fill the caliper and lines so make sure you always have enogh in the resiovr.
like i said it may seem stupid but i had a freind try and bleed his brakes with the valve open .
