Help withram air covers
Old Apr 9, 2009 | 09:37 AM
jasonpbraun's Avatar
Default Help withram air covers
Can someone take a picture of where their ram air covers hook onto the front upper fairing? I bought a uses 2002 cbr and the covers are not bolted down and have no bolts or attatchments to bolt them on the fairing, but the covers have holes for so.
Thanks
Old Apr 9, 2009 | 11:23 AM
Joey_f4i's Avatar
Had the exact same problem, I guess some nuckle head mechanic misplaced the allen bolts.
They have the complete sketch of what you are missing and where it goes here :
http://www.bikebandit.com/houseofmot...4-2002/o/m2051
you can also order the exact missing oem Allen bolts there.
make sure you get any grommets, spacers and backings you might need for the bolts you order.
Old Apr 9, 2009 | 11:35 AM
Default no bolts
Where my covers hook there is no place to screw in bolts and i do not see any place where a bracket is broke or where it would attatch.
Old Apr 9, 2009 | 11:43 AM
Joey_f4i's Avatar
did you check out the detailed diagrams at bikebandit?
they pretty much show you every single part of your bike and where it should go.
Old Apr 9, 2009 | 11:46 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Smile
You'll see two tabs on either side of the upper, the inside ones (broken on mine) are for the headlight assembly, and the two outside ones are for the intake covers.
Left side:
Right side. This one had to be repaired with epoxy.
Old Apr 9, 2009 | 10:56 PM
Default thanks
that helps a lot, thanks
Old Apr 10, 2009 | 01:57 AM
Aken's Avatar
July 2008 ROTM
You may have broken tabs, or an aftermarket upper fairing, which doesn't usually come with the same quality as OEM.
AAA817
Feb 24, 2012 09:57 AM
CodyJ28
F4i - Wanted
Aug 23, 2011 02:19 PM
new06f4iowner
Jun 3, 2010 01:22 PM
