help removing handle on 2004 f4i
Old Oct 5, 2006 | 08:36 PM
adam833's Avatar
Default help removing handle on 2004 f4i
I am trying to get these 4 hex bolts off and my hex rench is stripping the inside or vice versa...any suggestions how to get these off? thx
[IMG]local://upfiles/10656/F265FF26093342F2B82B800370CB4C71.jpg[/IMG]
Old Oct 5, 2006 | 08:42 PM
F4Isvt's Avatar
Default RE: help removing handle on 2004 f4i
Hate to sound stupid but find the right size allen wrench. I have taken mine off numerous times and finally once and for all as I filled the holes.
Old Oct 5, 2006 | 09:04 PM
traitorhound's Avatar
ORIGINAL: F4Isvt
+1 on that
if that isn't the case i would say get some penetrating fluid and spray the inside where the bolt goes into the subframe and let it sit for awhile and that may looses it up. 3/8th impact?
Old Oct 5, 2006 | 10:08 PM
woot's Avatar
Should be metric? Unless it is an odd part, almost all Japanese bikes are metric.
I'm not going to say it isn't SAE, but it just seems unlikely.
I wish I had a grab rail for my F4... be good for the times I have a passenger.
Old Oct 5, 2006 | 10:37 PM
adam833's Avatar
its not metric, its 7/32...I was doing it with the little L shape wrenches but I guess I am going to get a socket set with hex bits
Old Oct 6, 2006 | 12:37 AM
abadfish's Avatar
ORIGINAL: adam833
Why are you asking for help if you're not willing to listen to the advice people are giving you???? It is metric. The reason you are stripping it is because you're using the wrong size allen key. A socket set will do the same thing if its the wrong size.
Old Oct 6, 2006 | 02:38 AM
jimd2p's Avatar
Definately metric. Everything on the bike is metric. Use a decent quality tool and the right size and it will make life easy.
Old Oct 6, 2006 | 02:46 AM
maximus3's Avatar
+1 on that
metric all the way i took my bike a part with a set of metric allen key'
Old Oct 6, 2006 | 03:23 AM
Leveltwo's Avatar
i had the same problem on mine, they are a soft bolt, so if you use too much force it will strip...i was using the right size but it came out once and bent one of the sides, and ever since it has just eaten away with every turn...luckily for me i am in the process of plastic welding the holes and painting over them cause it looks so much better with that ugly bar off the rear
Old Oct 6, 2006 | 03:43 AM
adam833's Avatar
I bought a set of metric and none fit, either too small or too big, If somebody knows the size please post? The only thing that fits is a 7/32. I also figured it would be metric since its from japan thats why I bought the metric set today
