HELP no start after panic stop!
Old 10-27-2007, 10:19 PM
jjbtao's Avatar
Default RE: HELP no start after panic stop!
Fuel pump relay is under the tail fairing... could have been damaged or had the plug jarred loose in the landing... sounds unlikely, but all of the other scenarios (kill switch, kickstand switch, tip over sensor) wouldn't allow the engine to crank over still... when you turn the key to the on position, do you hear the fuel pump? does the FI light go out after a second? That's where I'd start... no fuel=crank, crank, crank, no start...
Old 10-28-2007, 04:31 PM
notoriousracing's Avatar
Ok found the relays, and fuel pump definatly seems to not be turning one. There are two relays, one closer to the front of the bike and one towards the rea, anyone know which pins to jump to bypass the relay?
Old 10-29-2007, 02:37 AM
Ok folks, the forward mounted relay is the fuel pump relay, i bypassed the relay with a jumper wire and bam! She purrs like a kitten. Lets just say I now know how to hotwire an F4i from this experience
Thanks for the help guys!
johnk16
03-22-2014 09:16 AM
sephrin
12-03-2013 11:10 AM
Tweeter03
06-11-2010 11:09 PM
abelg
07-19-2009 07:23 AM
st3veo89
10-09-2008 11:24 PM
Quick Reply: HELP no start after panic stop!
