help no head light?
Old Nov 1, 2006 | 04:07 PM
raredogg's Avatar
Default help no head light?
I may have found the reason my why head light dont work, there is a 20 amp connection next to the flasher relay in the front nose, took a ohm and there is no continuity on the + side but there is on the neg side, any suggestions? the high or low! the high blue light in the instrament cluster alluminates when the key is turned.
Old Nov 1, 2006 | 04:09 PM
raredogg's Avatar
Default RE: help no head light?
also there is voltage at the 10 amp fuse under the seat and also at teh connector on the left side under the air duct!
Old Nov 1, 2006 | 08:46 PM
Leveltwo's Avatar
something isnt connecting, are you talking about the big clump of wires that connect to turn your fuel pump on...if they arent connected, the headlight will not come on...maybe check you fuses again
Old Nov 1, 2006 | 10:18 PM
raredogg's Avatar
im talking about the grey connector under the left air duct that feeds power to turn cig horn running light and headlight. and there is 14 volts from the fuse when the bike is on! i was reading more on this issue and there might be a starter switch issue where others said the wires may break from the solder, i will check that and let you know, also i did a continuity check on the headlight relay that is in the upper cowl next to the flasher relay and the neg continuity side has it but the positive side dont, i heard that they rarley go out but do, so will keep the post alive until i find out wassop with it. thanks for relpies
dizzle46
Jan 29, 2008 05:33 PM
serge1284
Jan 21, 2008 04:22 PM
djtrix92
Dec 12, 2007 04:54 AM
clean929
Aug 10, 2007 12:12 PM
Shlock
Oct 2, 2005 04:07 AM
