Help with new sprockets and chain.
AFAM sprockets mo bettah alloy sprocket, DID is a fine chain, but a guy who cares for a chain religiously, frequent cleaning, adjusting, and lube can double chain life regardless of brand.
15/48 520 did chain on f4i trackbike.
IDL...which one are you interested in?
the 179 DID is cheap and a very good set up.
SLIP...you need a new rear sprocket...that's some crazy rust action you gots going on! muahahahah
ORIGINAL: Tahoe SC
Very important decision, of course!
IS there much difference between steel and alloy sprockets?
If i'm going to be changing the sprockets with each new chain I can't see there being much value in getting a sprocket that will last forever..
gold looks good on everything...the 80s are back...
true, but you wouldn't want a faster wearing sprocket to wear out the chain faster right?
both are pretty tough. i have afam aluminum rear on 520...as far as wear...it's all fine still...
why did i do 520? i thought i was going to go track only but dude...last 2 years = drastic life change...
had i known i'd stick with stock 525.
ORIGINAL: IDL
Damn, not sure if a gold chain would look good on my red and silver paint scheme
Dammit, now I'm on the fence. 520/525. Ihave 525 now and need a new chain FAST. I'm trying to ride tomorrow. Stealership's number is busy. Waaaaaaaaaaaaaa.
Can someone confirm that stock 525 is 110 links?
Since this is my first chain change I can probably do it myself...all I'd need is chain rivet tool, right? How do you cut the length?
I have a NIB 520 Vortex rear. Perhaps I can save a few dollars by just going 520 and getting a new front sproket.
Tomorrow is the day I make my purchase. When I get it installed, I will take some pictures and post here.
Thanks for all the suggestions and help.
Although, what should I get if I am looking to get a little more torque?
I found this link fairly informative on steel vs. aluminum sprockets, and also on the 520 conversion
Figure i'd post it
http://www.peterverdonedesigns.com/c...dsprockets.htm
I'm leaning towards the 525 chain now. Not sure how noticable the performance drop would be going from the 520 which is on now.
I do like the idea of the chain lasting much longer.. Call me cheap!
Figure i'd post it
