Help with MPG
Old Oct 11, 2009 | 03:49 PM
ars1986's Avatar
Default Help with MPG
I am running super rich on my 01 f4i. Like 20MPG. The only thing that i did recently was put a 07 R6 pipe on it. Because it looks Pimpy . Could this have caused the problem? I have done some research and found it could be the Fuel Pressure Regulator. But since i am really strapped for cash i need to know befor i buy something.
Any help would be greatly appreciated.
Old Oct 12, 2009 | 02:10 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
If anything, that pipe would make you run lean. Pull the vacumm line off of the FPR after its been running. If there's fuel in that nipple/hose, then it needs replacement.
Old Oct 12, 2009 | 04:34 AM
Zero1080's Avatar
Do you have said pictures of the pipe you can throw up? I'm looking for something a little sleeker.
Old Oct 12, 2009 | 06:57 PM
ars1986's Avatar
yeah i will take some pictures tomorrow since it is already dark out.
and thanks for the help with the FPR i will check that tomorrow also.
if anyone else has experienced this before, help would be greatly appreciated
Old Oct 15, 2009 | 04:54 PM
ars1986's Avatar
if anyone has experienced this before help would be great
Old Oct 16, 2009 | 12:56 PM
boredandstroked's Avatar
The exhaust will make it run worse but not 20mpg worse. Change your FPR.
Old Oct 16, 2009 | 10:42 PM
Elfling's Avatar
Ladies Lounge Moderator
Even more basic- what's your riding style? You redlining every time before you shift, that sort of thing? Not that it might not be something mechanical, just something else to consider. Depending on whether I'm behaving or not I can get quite a few more mpg than otherwise.
Old Oct 16, 2009 | 10:52 PM
abeer1's Avatar
Also check your plugs and air filter, this all affects your MPG.
Old Oct 17, 2009 | 11:57 PM
ars1986's Avatar
thanks to all. i have been doing all this stuff. and it is pointing to my FPR so we will see what happens from there
