Help on the headlights
Old Apr 18, 2012 | 02:43 PM
Moore.Speed's Avatar
Default Help on the headlights
I recently bought my first bike: 2004 CBR600F4i. I love the bike so far and I'm just getting started making some changes to it. I have a question about the headlights. I HATE how only one light is on when the low beams are on and I was wondering if I could get it to where both sides (bulbs) would be running when the low beams are on and also when the high beams were on which is hardly ever for me. Will an HID kit with dual beams or however they phrase it work for me? Or is running my high beams everywhere I go my only option? Thanks!
Old Apr 18, 2012 | 03:06 PM
joelluing's Avatar
only problem i see with using the high/low light bulb is that i do believe that the reflection angle of the highbeam is up "higher" so even if you had the duals and wired it to work I think it should blind everyone else that comes. unless that is if there is a way to adjust each bulb separately. Correct me if I'm wrong
Old Apr 18, 2012 | 03:24 PM
That would make sense. I asked a guy at a local shop if the "reflection angle" your talking about could be adjusted or taken out so that the high beam points just the same as the low and he didn't know of anything.
Old Apr 18, 2012 | 03:29 PM
jeffjones's Avatar
What you want is an HID Projector kit that will make both lights Lo and Hi beam. Bad part is you will have to rip your headlights open to install them. Any other way of doing it will be a ghetto hack job.
Old Apr 18, 2012 | 04:12 PM
Squirrel8811's Avatar
I have hids on mine. I hate the one headlight as well so since I do 95% city riding I just adjusted the high beam so its at the same level as the low. Everything is the same just the angle. So its a trade off. No high beam but no pirate eye.
Old Apr 18, 2012 | 08:28 PM
mnguyen84's Avatar
how did you adjust them?
Old Apr 18, 2012 | 11:30 PM
nickp123's Avatar
theres adjuster screws on the back of the headlight. One points the bulb left and right, the other points it up and down. So if you point the high beam down a little it wont be as blinding but you will lose some visibility obviously. Im not sure which screw of the screws moves it up and down and which way to turn it but just download a manual and go to the headlight section and itll tell you. Or maybe someone on here knows.
I usually just say screw it and ride with the highbeam on anyway. I really dont care if it annoys someone driving by me for half a second. Id rather be seen.
Old Apr 19, 2012 | 12:17 AM
svek's Avatar
The pirate eye is awesome. Just imagine you are winking at everyone
Old Apr 19, 2012 | 08:29 AM
Look at your right intake cover and there will be a hole in it. Stick a philips straight in and that will be your virtical adjustment.
Old Apr 19, 2012 | 07:56 PM
Thanks a lot guys for your replies. It has helped me out a lot. I'll look into adjusting it for now before i purchase HID's. If I get projector dual beam bulbs, then all I need to do is just adjust the angle of the high beam now and the high/low bulbs will both run as I turn them on/off?
Also, if any of you already have this HID kit installed or know a good, reliable site to find them, post the link! Thanks again
