HELP: canister holding bolt alignment issue
Hey guys. I'm in need of help. Ever since I cant afford a mechanic I am obligated to do all the maintenance on my 04 f4i by myself. the previous owner of the bike had the Evap Purge Control Solenoid Valve just dangling by the canister so last night I've tried to relocate it and bolt it down so it would not get caught by the chain. The canister is held by a long bolt that goes all the way across. I've tried taking it out, but after a while it would get stucked. So I decided to screw it back up. As I look at the other side where the bolt supposed to go in, I've noticed that the alignment between the bolt and the hole was off a bit. Does any of you know whats the best way to fix that? I am so helpless rightnow considering so many hours I've put into that bike and learning about it since the time I got it. Also, do you guys know where the Evap Purge Control Solenoid Valve should be located at? I'm thinking to just zip tie it to the frame. Please help me!
Sounds like that bike has been down, and now the subframe is tweaked a lil. Just zip tie up outta the way. If it really bothers you, then pick up a used one. You can get one for pretty cheap since alot of folks are switching over to the split seat set up. (Banana/split mod) I would suggest removing all the fairings and going over the bike with a fine toothed comb. Check for irregularities/stresses in the frame, check the welds for cracks, check the forks out too. Leaky seals, score marks in the metal, different height settings. Good luck bro.
Hit it with a shuryukin uppercut, it'll go in there.
Thats not an F4i swingarm...it looks like it came off an RR. And its kinda hard to tell from the pics, but the mounting surface where the bolt goes looks chewed up some. That looks like the dog-bone for the rear suspension, mine is hooked up to the holes right above where you are trying to put it, but I got a stock swingarm. And part of doing that mod requires modification to the suspension. When you decide to replace the chain and sprockets, you'll need a longer chain cause the RR swinger is 2 inches longer than stock, so count the links before ordering.
thanks a lot for your input. i think you are right about the swingarm, because i know for a fact that the rear frame is off of '05 RR (at least that's what it says). i did not know about the chain, so i will take your advice when shopping for a new chain. do you know where the purge solenoid valve goes?
When you refer to the rear frame, are you talking about what the seats bolt up too? It looks like it goes on the left side of the bike (if sitting on it) behind the heel gaurd. Do a search and D/L the manual. You're gonna need it since you're doing your own work. (mostly for torque values)
