HELP! 2002 Honda CBR F4I not working
So short story is I accidentally plugged in my new battery the wrong way and noticed nothing was turning on, I looked at my battery and was beyond frustrated with my self. What do I do?? People have told me to look at the main fuse but I am having the worst time finding this. I found one 30A fuse under the seat but that's all. Is there another place I should be looking for it? Please I really need all the help I can get.
Thank you! |
2 Attachment(s)
Have a look here, also the 20amp
Can’t seem to get a chance to look at the image, a admin has to approve my account to do so. |
I can’t seem to look at the image, an admin has to approve my account |
Have you got the manual ,if not here
StephyGee.com |
Oh, I think I might have been looking at the right direction but instead I took out the spare 30A fuse for the motorcycle, so what this is saying is that I need to open up the cable and then inside it should be the actual fuse?
The major big problem is I don't know how to do this, it says to hold down each side and it should make a click, however it's broken idk what happened to it, so this makes it near an impossible task to get it out without having to **** it up some kind of way, any suggestions?
Can you confirm if this is what I am suppose to be looking at and that that is the spare? https://imgur.com/gallery/HeQIQ |
Yes just grip the red holder at the two sides squeeze those two sides at the top and pull up, it will be quite stiff, then check the 20amp fuse for the fuel pump, that should be along side the fuse box, did you get the manual
Yes I got the manual and looked over it, I understand what I have to do now. When I get home later tonight I will attempt to get this out and put the spare in, I am praying it is blown so all I have to do is replace it and start her back up. I will update once this is done, thank you for all the help so far!
