Help!!!
My bike will start with no issues. After about a minute or 2 it shuts off and all the lights on the display will stay on . As long as those lights are on the bike will not re-start.The headlight stops working, the blinkers and I don't hear the whining from the fuel pump. I don't know what s causing it to shut off or how to prevent the lights from coming on. Help me figure out whats wrong.....https://lh3.googleusercontent.com/s2...=w1034-h775-no
Hi matey, strange, when the lights on the panel are on , are the headlights on and are the signals on , or is it just the instrument lights that are on , I see from your picture their on but wasn't sure if the headlights and indicators are on
I would start with the fuel pump, filter, and/or lines. Keep in mind, I'm not anything close to an expert!
Originally Posted by CaBaRet
(Post 1314870)
Hi do you get any fault codes, and have you checked any of the harness connectors for heat, I say this because it seems once your bike has been switched on for a while the problems start, leads me to think its electrical, can you try switching ignition on ,dont start the engine and see if the same happens, unfortunately will run down your battery though, and if the lights go out check the harness connectors for heat
