Hello everyone. I just bought a cbr and have a few questions.
Old Mar 18, 2011 | 10:09 PM
01hondaf4i's Avatar
Default Hello everyone. I just bought a cbr and have a few questions.
I picked up a 01 f4i for $800. The frame needs replaced because a garage collapse and dented the frame and cant get it inspected. Any ways the bike supposly needs "fuel pump relays" the ones in this pic-the two under tail. What are these relays exactly and would they stop the bike from getting fuel. The guy claims he put too much stabilizer in it and it ruined the pump. He replaced the pump and he said it burned up the relays.
What do you guys think.
Attached Thumbnails Hello everyone. I just bought a cbr and have a few questions.-0317111618_01.jpg
Old Mar 19, 2011 | 09:51 AM
jp_greenville13's Avatar
Those are the engine stop and fuel pump relay's. Yes it could keep your bike from getting fuel
Old Mar 19, 2011 | 12:16 PM
AlexF4i227's Avatar
something similiar happend to me but with a bad fuel pump relay when you turn the key and hit the engine on switch you will hear nothing no priming or nothing just have both them changed to be on the safe side and check the ecu for loose wires
Old Mar 19, 2011 | 09:38 PM
01hondaf4i's Avatar
Thanks guys. The dealer said $30 a piece.
Old Mar 19, 2011 | 09:43 PM
01hondaf4i's Avatar
Also. Do I need any special tools to swap the forks or swing arm over to the other frame?
Old Mar 22, 2011 | 11:09 AM
01hondaf4i's Avatar
Any input?
Old Mar 22, 2011 | 12:08 PM
nowensby's Avatar
Do you already have another frame with title?
Old Mar 22, 2011 | 12:20 PM
ROOKIE 09's Avatar
Would this have anything to do with first time starting my bike this year I heard nothing when I turned the key.. Then I rolled the bike and heard it prime and started right up..
Old Mar 23, 2011 | 11:15 AM
01hondaf4i's Avatar
Yup its on it way already.
I'm going to get it running before I swap frames.
But do I need an special tools for removing forks or swing arm or anything for that matter? When I did a gixxer motor I need a special socket.
Old Mar 23, 2011 | 12:38 PM
crazychris1981's Avatar
on the swing arm you have the bolt and nut that goes threw the frame and swing arm, after you get that off you have two large adjusters that you will need a tool for either get one from honda or make one like a lot of people do..i didn't see it on other how too's but on mine there are two more adjusters that i had to make a tool for that allow the swing arm to come off...
