head lights dont work? eff
helpz! i ahve no idea what the problem is, i used a voltage meter and getting power threw my fuses all the way up to the wiring harness on the front fairing which connects to the headlights, and side blinkers... however one of the white wires doesnt seem to get power could be this the problem?
RE: head lights dont work? eff
One thing you should try doing is to take apart starter/kill switch on the right clip-on to check and make sure a connection in there did not come unsoldered. It is only 2 screws to undo it and check it. There is a wire for the headlights that runs into that switch that cuts the power to the lights when you hit the start button. If that got too hot and came unsoldered it would cause the lights to not work. If that is the case then just resolder and your set, if thats not it then keep looking. Good luck.
