Handlebar Raisers
Old Feb 15, 2013 | 03:07 PM
RANGERRICK's Avatar
Registered Users
Default Handlebar Raisers
Brothers, I would like to raise the Handlebars to ease the pain of aging, any thoughts, best products, installation, etc ? Thank you in advance Gents !
Old Feb 15, 2013 | 06:37 PM
MadHattr059's Avatar
DanMoto makes em, APEX engineering, Heli-bars, couple of others.
Do a search for rear-sets/bar risers.
Some of them are 'kits', i.e. the manufactuer swears they'll work with stock cables.
They generally will only do a mild off-set from stock, though.
If you lift/rear-set more than about 2", expect to replace all of the cable/lines.
If you use string, you can get a good estimate of the new lengths needed.
Any setback, will also raise you up, more into the air-stream.
You might consider adding a winglet/foil to your windshield,
or look for a touring version of your OEM.
Hope this helps, Ern
jarvid
Jul 3, 2011 06:26 AM
MuscleswitCBR
Sep 11, 2010 01:30 AM
hurayta
Oct 19, 2008 05:41 PM
PlayfulGod
Sep 27, 2007 07:50 PM
karlo
May 5, 2006 06:44 AM
