GPS Mount
Old May 8, 2009 | 07:54 AM
Glocker23's Avatar
Default GPS Mount
I bought a GPS and am looking at a mount from ram-mount.com. I am looking to mount it to the top of the tree. Question is the the triple tree stem hollow. That is how this one would mount. Need to confirm.
Old May 8, 2009 | 08:00 AM
shawnyc01f4i's Avatar
Believe so, just a plastic plug that slides in the top to cover it. Comes right out.
Old May 8, 2009 | 08:05 AM
Glocker23's Avatar
just pry it off with a screw driver???
Old May 8, 2009 | 08:25 AM
Glocker23's Avatar
nm just walked outside to check it. easy as pie.
delete thread
Old May 8, 2009 | 10:32 AM
dave ls1's Avatar
nah keep the thread, maybe someone will search the same question in the future.
Old May 8, 2009 | 06:08 PM
Berto's Avatar
Here are a couple of pix of the RAM mount. It consists of a conical plug that fits down into the stem and expands via a screw in the center of the mount.
It doesn't hold all that well, to be honest. The mount won't come out, but it will turn and change position when you don't want it to.
To solve this problem, run a threaded rod all the way to the bottom of the stem--it's hollow the entire way down--and secure it with a large fender washer and a self-locking nut. At the top, you'll need a little threaded rod coupling to join the screw to the rod. Hardware stores have them.
For a heavyish GPS, you'll want the added security.
--Paul
Old May 8, 2009 | 07:31 PM
Zero1080's Avatar
I work at Best Buy on occasion (long story). But I did a job for a friend where we put his gps to the windscreen, with the suction cup mount, however, we epoxied it there, so it won't be going anywhere, then hardwired a charge cord to the accessory, beautiful job. I'll try and get pics.
Old May 8, 2009 | 07:38 PM
woot's Avatar
for what it is worth... I mounted my ram mount onto the 2 bolts that hold the front of the gas tank... those don't move anywhere!
Old May 8, 2009 | 07:42 PM
Zero1080's Avatar
^^HEATED grips?!? Do explain. I likey...
Old May 8, 2009 | 07:53 PM
rolandk's Avatar
Heres my setup:
Bought the mount off of ebay, it goes all the way through to bottom of the stem.
