-   F4i - Main Forum (https://cbrforum.com/forum/f4i-main-forum-11/)
-   -   Gas tank leak (https://cbrforum.com/forum/f4i-main-forum-11/gas-tank-leak-145292/)
jacksla3 Mar 13, 2013 08:32 PM
Gas tank leak
Hey, is there a special gasket sealant for use for where the fuel pump meets the tank?
stlcbr600f4_newb Mar 13, 2013 10:31 PM
yes it is suggested in the manual that you replace the "fuel pump packing" after every removal.... but it you have a leake and recently removed the fuel pump and have a leak .. remove and check for the stainless packing strands aren't caught in the gasket..
had the same issue that's all it was i have removed and installed my pump 4 times with the same packing... and you have to do cross over tightening ... for even and uniform seating of the pump
mnguyen84 Mar 13, 2013 10:39 PM
unless that big rubber gasket is damaged..it shouldn't leak if u bolted it on correctly. ask the dude at Autozone about the sealant thing.
