gas gauge
RE: gas gauge
Somehow I get the feeling you've never seen the reserve come on...
When you turn the bike on, the gauges do a self test. At the time the entire LCD 'lights' (or rather 'darks') up. You should see a set of black boxes forming a thick vertical bar near the left end of the LCD gauge. That's your reserve indicator. Ride till you see it light. Then you have 30-40 mi to go depending on your mileage. Mine doesnt come on till 150mi on a full tank.
I've never seen 180 in the time that I can remember. But I've had an untuned PCIII for a while, so that doesn't help. I average about 130 before reserve kicks on.
I actually read the manual this morning!!
It says the fuel gauge only comes on when 1/4th tank of fuel is left.
For the gauge to disappear, you need to have all of the following:
1. Fill up fuel to more than 1/4th tank
2. Side stand is Up
3. At least 90 seconds have passed since you filled up.
As others said, check when you turn on the ignition if it shows up on the LCD.
If yes, then try riding and see if it comes on finally.
2. Side stand is Up
2. Side stand is Up
2. Side stand is Up
my 04 cbr f4i does the same thing, everything works when i turn ignition, but does not work when on reserve. i ran it until it shut off on me like around 200 miles.
Armstrong
06-08-2006 08:31 PM
