fuses names?
Old Oct 10, 2009 | 09:56 PM
eljrc16's Avatar
Default fuses names?
Can somebody please show me a list of the names of each fuse? I know there is five of them, so from top to bottom name them.
Old Oct 10, 2009 | 10:55 PM
ZIP5K's Avatar
Default 2001 fuse box
I FOUND THIS ONLINE ITS FOR A 2001 HONDA CBR F4I. I HAVE A 2002 ITS ALMOST THE SAME. I HOPE THIS HELPS.
Old Oct 10, 2009 | 11:41 PM
eljrc16's Avatar
Another question should I use 10 or 20 in size?
Old Oct 10, 2009 | 11:53 PM
ZIP5K's Avatar
What year is your bike ON MY BIKE EVERYTHING IS 10 IN THE BOX ONLY THE FAN FUSE IN THE FUSE BOX IS 20.THERE IS ALSO A SMALL FUSE HOLDER CONNECTED TO THE FUSE BOX WITH A 20 AMP FUSE. 2002 F4I
Old Oct 11, 2009 | 12:22 AM
eljrc16's Avatar
2001 f4i. it already burned my 10 one already thats why.
Old Oct 11, 2009 | 12:43 AM
ZIP5K's Avatar
From top to bottom the one that burned out is in what place. Have you changed anything or did this just start to happen? The best advice I can give you is to start checking your wire harness. Once you know what fuse it is that keeps burning out you should back track the wire harness to check the wires that are going to it. My friend he has a 2001 F4I, so I will compare his fuse box to mine. I will let you know and take a pic just in case you don't have it fixed.
Old Oct 11, 2009 | 05:35 PM
eljrc16's Avatar
can I use a 20 fuse on the 3rd slot from top to bottom? please help I need to go buy some fuses.
Old Oct 11, 2009 | 10:19 PM
ZIP5K's Avatar
Talking fuse
I wouldn't use a 20 you might do more damage. The 3rd fuse should be 10 ind/meter/tail/illumi. If you search online you can download a service manual for the f4i. I know you might not want to hear this, but I would say take it to the dealer. By putting a bigger fuse you might damage something that will cost more than what you wanted. I'M SORRY I couldn't be of more help.
Old Oct 11, 2009 | 11:11 PM
letsride's Avatar
If you are burning your fuses it's most likely that you have a short somewhere.
Old Oct 12, 2009 | 05:05 PM
eljrc16's Avatar
how can I check where I have that short? Any ideas you guys can give me. I am really **** about having things on my bike not working properly.
