fuses names?
From top to bottom the one that burned out is in what place. Have you changed anything or did this just start to happen? The best advice I can give you is to start checking your wire harness. Once you know what fuse it is that keeps burning out you should back track the wire harness to check the wires that are going to it. My friend he has a 2001 F4I, so I will compare his fuse box to mine. I will let you know and take a pic just in case you don't have it fixed.
![Talking](https://cbrforum.com/forum/images/icons/icon10.gif)
I wouldn't use a 20 you might do more damage. The 3rd fuse should be 10 ind/meter/tail/illumi. If you search online you can download a service manual for the f4i. I know you might not want to hear this, but I would say take it to the dealer. By putting a bigger fuse you might damage something that will cost more than what you wanted. I'M SORRY I couldn't be of more help.
![Icon No](https://cbrforum.com/forum/images/smilies/icon_no.gif)
