Fuel tank removal
Do you lose all of the fuel in your tank when you pull the tank? Or do you just lose a little bit of fuel that's left in the fuel pump?
RE: Fuel tank removal
It will keep coming out from my experience. I just capped it with a bolt until I was done.
are you pulling the fuel pump or something? or just the tank? because if your just taking off your take. you should just turn your fuel off when you get the take up, before you pull your fuel lines turn off the fuel. and you should very little of fuel. and if your talking about replacing the fuel pump just flip your take upside down, and you don't lose any. because your fuel pump doesn't hold fuel. thats why it primes when you turn the key on. hope that helps
No, I'm not replacing the pump, just pulling the tank. So, just follow the instructions in the manual and I should be ok? Even on a full tank?
