Fuel tank removal
RE: Fuel tank removal
are you pulling the fuel pump or something? or just the tank? because if your just taking off your take. you should just turn your fuel off when you get the take up, before you pull your fuel lines turn off the fuel. and you should very little of fuel. and if your talking about replacing the fuel pump just flip your take upside down, and you don't lose any. because your fuel pump doesn't hold fuel. thats why it primes when you turn the key on. hope that helps
