fuel pump won't kick on...
had a wreck and it fell to the side but no major damage, but when i tried to turn it back on all that happens is the motor turns but i don't here the fuel pump, this may sound weird but previous owner bypassed the fuel relay and it works fine with me like that, so when i turn the key its off till i turn the kill switch on and i can hear the pump turn on but now i hear nothing so i know its the fuel pump not kicking on thats the culprit, i also checked any fuses i could find and i checked the tilt sensor and it all seems to be fine.... i need pointers plz i need to ride it clears my head...
Try bypassing the tilt sensor. It may be stuck internally.
man u always come to my save 74demon, any idea on how i bypass it? i know it has three leads
Jump the outside wires....
yup just found the diy, tks man ill update u afterwards give me 15 min
batteries dead :/ gonna charge it give it an hour
post poned :/ pouring outside ill update when i can
alright so i bypasses it and yup i think it may be stuck also now cause i heard it kick on, couldn't turn the motor tho cause i opened the kill switch and a connection got loose ima try and solder it back together and try and give it a go
