Fork oil level
Old Apr 28, 2015 | 02:57 PM
Ls1Mx5's Avatar
Default Fork oil level
I've checked many how to threads and the service manual but I'm still confused. How do I know when the fork oil is at the correct point? I know it should be at "116mm" but how do I know when it reaches or exceeds that point? Thanks in advance
Old Apr 28, 2015 | 04:13 PM
74demon's Avatar
The manual will give you the depth from the top where the fluid should be at. Make yourself a dipstick. I use a zip tie and cut a notch at the right measurement (70mm for me but 116 mm for you if that's what it says) from the bottom of the square part. The keep adding until it reads at the notch.
Don't forget to pump it 20 times to bleed it before dialing in the level.
Old Apr 29, 2015 | 11:58 AM
Colombo's Avatar
What is this form oil I'm reading about? I'm a noob and know very little about bikes. Perhaps a little elaboration for this noob
Old May 5, 2015 | 11:53 AM
Ls1Mx5's Avatar
Ahh now I understand what they mean. Thank you
Old May 5, 2015 | 12:20 PM
74demon's Avatar
Your forks have oil in them. It should be changed with new seals every few years.
schmittyf2
Jun 2, 2010 05:36 PM
WhiteHawk
Mar 17, 2009 10:17 AM
suzuki2903
Dec 13, 2008 08:03 PM
ducati_nolan
Apr 27, 2007 03:55 AM
hurricane666
Apr 22, 2007 05:18 PM
